hi has anyone lowered their roof? what o you do for rubbers and windows. where do you go to get them done?
The side glass can all be made easily, it is flat glass, any glass place can cut it out from a template (that you make) and get it tempered to pass engineering. Front screen can be cut down if laminated. Rear screen as far as I know would have to be made of perspex or cut from a laminated front windscreen of a vehicle that has the same curvature, or the original back screen fitted with a tilt. Time is needed
Rubbers have to be cut by hand and glued as required. Time is needed
Basically unless you know what to do, and do it all yourself, you may end up with a scrap metal shell, or an unfinished project being sold on ebay.
If you know what to do, and have all of the skill, tools, knowledge, time and money, then you may end up with a really nice car.
Learner ·
cheers. i just needed to know how it was done... i have been thinking about it for a long while now. knowing that it is inded possible, it might come true
greedy53 ·
hot rod mat had or has one shell with the glass and if u put the question up on flat four .org there is a couple of them that has one or had one
good
