Aussieveedubbers 路 Tech Talk
Replacing Crank Pulley
https://forums.aussieveedubbers.com/threads/62946/replacing-crank-pulley
56astro 路
I need to take the old one off and replace it with another.
Are there any traps for the novice?
Do I need special tools?
Do I need a torque wrench to tighten the new one?
13bwagon 路
um there is a little tinware to take off then when you have the big nut off use a nice puller to remove it then id use a little lube 馃檪 on the new one the a nice bit of timber to tap it in oh and put the nut back on 馃檪 just do it up nice and tight not to hard!
56astro 路
How tight is "nice and tight"?
PurpleT3 路
Is the engine in or out of the car? If out you will either need a fly wheel lock or a bit of anlge iron to stop the motor from turning.
If you do not have a calibrated arm, I would suggest you use a torque wrench to do up the nut.
56astro 路
Thanks PT3
It's out of the car, and I think I have a flywheel lock lying around somewhere.
56astro 路
Found it - 4.5 m/kg or 33 ft/lb
