Blocking Off Dizzy and Fuel Pump Holes
https://forums.aussieveedubbers.com/threads/62947/blocking-off-dizzy-and-fuel-pump-holes
56astro ·
I have removed the dizzy and mechanical fuel pump.
I have a plug for the dizzy hole and a block-off plate for the fuel pump hole.
Is there anything else I need to remove from the holes before I block them off? I thought I had read somewhere that I need to remove a gear or spacer or something from the dizzy drive?
If I need to get something else out, do I need special tools?
13bwagon ·
what are you doing?? cleaning?
yeah you need a special tool to remore the dizzy drive sharf
56astro ·
What am I doing ......
http://forums.aussieveedubbers.com/viewtopic.php?tid=57814
And on your 2nd point .....
bugga!
Menangler ·
Steve,
You should be able to remove the dizzy drive with a good set of flat nose external circlip pliers, turn the gear as you remove it, don't forget the 2 small washers on the end if the gear they usually stay in the case, use a magnet to get them out.
Dave
hellbugged ·
we've got the tool if you need it Steve
56astro ·
That'd be great, Daimo.
I'm off for the rest of the week (till Sunday).
56astro ·
Thanks Dave,
I hear that if the shims/washers fall back in they can drop right down into the case, resulting in a complete tear-down.
yes the shaft and shims other wise they will jam up in the cam gear
johny rotten ·
I bet you will be glad to see the back of that huge dizzy .
johny rotten wrote:I bet you will be glad to see the back of that huge dizzy .
Those big distributors work very well, but you gotta be able to count using the fingers of more than one hand to install the leads!!
56astro ·
I'll be glad to see the end of the carbies.
The improvement the big dizzy and twin ignition made is remarkable.
Thanks for all the tips.
