I am in the process of fitting the engine management harness of my Subaru EJ20 engine to the Manx SR. I have had it reduced to its essentials but some of the wires are over a meter too long for a good looking fit, with nowhere to tuck them away out of sight.
If I cut them and solder every join will that do the job without problems?
MickH ·
yep.:bounce
Yep... only do one wire at a time, though!! Also, use heatshrink and try and stagger each join so they don't 'thicken' the harness at one point
And make sure there are NO three-way splices hidden in the harness that you don't know about; sometimes one wire can become two along its length
shaihulud ·
Thank you gentlemen.
I was hoping that it would be O.K.
Thanks for the suggestions, especially the 3 way splices and staggered joins ideas.
If there is anything that I have learned from my first experience with a ECU engine, it's that there are plenty of traps for the unwary.
