End float???
https://forums.aussieveedubbers.com/threads/6306/end-float
Andy42 ·
How much end float is acceptable in a type 4 crank(1800).
KruizinKombi ·
0.07-0.13mm (0.0027-0.005 in) taken at No. 1 bearing.
KruizinKombi ·
Oops, wear limit is 0.15mm (6 thou). 🙂
Andy42 ·
OH so if I can move the crank back and forward about three mm that must be ..... well....stuffed
KruizinKombi ·
Ah.... yeah :o
I've never been in that situation, but maybe some bearings might help?
I would say that the case will need maching as well.
but more than likely its stuffed altogether as the thrust surface on the number one bearing will be gone.
