*Tip*-Cleaning shower glass
https://forums.aussieveedubbers.com/threads/63069/tip-cleaning-shower-glass
5PL1TDCS10N 路
While doing the usual chores I found a $!#@ easy way to clean the shower glass in seconds!(and the results were A++)....I used General Purpose Thinners and just wipe on/wipe off!
I will see what else I can use it on....hehe
W馃檪
bond 路
wont you eventually craze the glass?
nick
Notch Nut 路
I'll pass that on to my wife. Cheers:thumb
- Adam
helbus 路
Will it affect any silastic or sealant that is bonding the glass in?
baybuscamperkid 路
compayo wrote:Will it affect any silastic or sealant that is bonding the glass in?
my thoughts exactly, then again its probably less toxic then some of the other stuff!
Notch Nut 路
It also makes an effective weed killer for driveways/paths etc.
BeetleJuice 路
Commercial cleaners use a product called "Hound Dog" on glass that is water stained. My freind put me onto this a few years ago....But always use gloves!
5PL1TDCS10N 路
I put some on a rag then just wiped on/wiped off. I was carefull around the seals though. Better than bleach, no water wasted...and the fumes make you high!:thumb
I use hot boiling water for weeds. 90% environmentally friendly(the 10% is the power needed to use the kettle)
W馃檪
BASHOdi 路
Metho will work a treat.
+ add a loaf of bread for the strainer and you could also have a party bruder.馃シ
