Bought with a heap of stuff already done have re-done all the front suspension all replaced with new , brakes--all linings , cylinders , single master replaced with twin (today) -all replaced with new-- gearbox --replaced with 1500 ---Clutch replaced at the same time with new German as the high pressure one in the car was a PITA in traffic and gross overkill --reupholstered interior, new seats at the front, re-wired, replaced with marine and relocated fuse box so I could install ICE (ClarionDB566USB) Sony speakers no secondary amp or sub --quite honestly I dont need it--it already shakes thew windows loose as it is. Installed the origional radio which works independantly like on one speaker (Jensen) amazingly good sound , relocated the washer bottle to under the back seat tubed the rear speaker wire and the washerbottle electrics to run to the rear .Runnining a worked 1641 re-build (bought with car) with a Scat C35 cam 12.5lb flywheel , 38mm twin throat webber on custom s/s manifold re-worked case and a load of all new and worked engine bits.
And still aint near finished.
clik tO MAKE BIG
[ Edited on 3-8-2007 by BASHOdi ]
BASHOdi ·
