old school turbo setup
https://forums.aussieveedubbers.com/threads/63126/old-school-turbo-setup
aussiebaja ·
hi guys could you please tell me what i would need to setup my baja 1200 with a small but good turbo ,but i want to do it old school without all the intercoolers ,water injection and stuff ,,,,thanx ,,,,
no im not gonna put in a bigger engine ,so please dont suggest that
Stanley ·
a turbo
a carb, I suggest you use a draw thru. I have had good success with an SU
an intake manifold to suit your turbo
a bigger oil pump and oil filter set up and a means for getting the turbo oil back into the case, maybe thru your rocker cover.
An exhaust manifold.
and plenty of research....get a copy of turbomania...good source for oldskool stuff...and plent of surfing (the net that is)
These are the basics but it's where you need to start.
buy a judson super charger of Ebay
there around $1500 for a full kit they come up from time to time
aussiebaja ·
thanx guys,would a bigger oil pump off a 1600 ,1800 fit and work or should i get something else ,,what size su should i use ?
[ Edited on 14-6-2007 by aussiebaja ]
why would you bother?
bond ·
i agree. anyway.
doesnt get much more "old school" than
http://www.thesamba.com/vw/classifieds/detail.php?id=452615
or you could go "old school" and go n/a....
goodluck
nick
bond ·
woops. you would be single port lol. but you get the idea 🙂
nick
aussiebaja ·
why would you do something like that when you could do a similiar setup to kroozen63 baja,i thought you guys might help but ,,,,,,i guess not ,,,,,,,,,,,,,,,,,,,,,,,thanx stanley for your help anyway
No the pumps are a different size
try the Judson set up its a bit of extra boost but the kits are getting expensive now days
The Twin carby set ups give better torque on the small engines
koolkarmakombi ·
ooooh, meow!
Giving more of an idea and discussion of what you want will get you more discussion back.
http://forums.aussieveedubbers.com/viewtopic.php?tid=63141#pid596899
1200 cranks are spindly flexy things.
The engine will require a good once over. If you are asking the oil pump question you will prob get better cheaper result by adding cubes.
aussiebaja wrote:why would you do something like that when you could do a similiar setup to kroozen63 baja,i thought you guys might help but ,,,,,,i guess not ,,,,,,,,,,,,,,,,,,,,,,,thanx stanley for your help anyway
Stanley ·
Sorry aussie baja but I kinda agree with the other guys. Old skool doesn't mean cheap. The TAT owes me more than it cost to fit a suby to my sons kombi. But I did it just to do it basically. a 1916 may have been cheaper but everyone has one of those......:P
At the end of the day it's up to you...just do your homework
aussiebaja ·
up where i live around the new england there's a lot of hilly running and so the idea of a small turbo setup ,i know the bigger donk would be better but there's no challenge in that ,i just like the idea of setting up a small turbo to help push her up the hills and have a little fun ,if or when it blows up ill go the bigger donk then, but while its goin fine i thought ide give it a go ,if i can pick up a good second hand turbo and do all the rest of the work myself i cant see why i cant get away with spending less than $1000,ive got a well equiped workshop to use
