Aussieveedubbers 路 Buying, Selling & Swapping Parts
Dak-A-Tak needs help(carbs)
https://forums.aussieveedubbers.com/threads/63153/dak-a-tak-needs-helpcarbs
Dak-A-Tak 路
Warwick isn't far off !!!!!!! I'm trying to get 3 cars to warwick ( 48-ida , Yellow car , choptop red&black ) ,the
problem is I have put my scat motor in the yellow car out of the choptop .
The choptop is getting a 2500cc type 4 out of my duel cab that I bought lately .
The car had a fire when a carb fitting broke off ,witch melted left carb and the heat also damage right carb .
It also burnt a hole beside one spark plug ,right through into chamber .(having this welded up).
AS my money is all going into Dak-A-Tak yellow car rebuild , I was hoping to BORROW a set of 45 Dellorto carbs for warwick week-end .
AS I do not know some-one that has a set .
They will only be used there !We, maybe able to work out a sponsor deal (a ride in car ,signage for business ,or something )and after event work out a SALE maybe !
I'm just trying to get as many cars to the event!!!!!!!!!!!
Thank you for reading !!!!!!!!!!!!!!!!!!!!!馃槉
Peter Page - QLD - 0409004767 ,07-32006805 .
[ Edited on 14-6-2007 by Dak-A-Tak ]
Craig Torrens 路
Peter I can lend you a set of 44idfs if that would help? with a range of jets !
andrewmurphy 路
Gday Peter
Not sure if he still has the car but Dangerous' had a set of 45' dells on his 1916.
Andrew
BiX 路
I have a set of 40 dells not doing anything at the moment you can borrow. Will need rejetting through as was for 1776.
Dasdubber 路
andrewmurphy wrote:Gday Peter
Andrew
Although I have to confirm it with Dave, I may also be 'borrowing' these 45 dells for Warwick. Unfortunately I don't think I will have my EFI and turbo setup ready so I'll have to run the type IV in N/A form.
I know your pain Pete! I wish I had a set of carbs to use....and another set I could lend to you!
Alan
dangerous 路
Those carbs will most likely be owned by Rod R by that time, but if not,
who ever is closest to the competion gets to use them.
Otherwise Rod can make the difficult descision!
They will need a thorough going through though.
hellbugged 路
i know where there is a boxful of carbs Pete (36 to 48's dells and webbers), will let you know some details soon.....
Dak-A-Tak 路
Thanks for all the great replys guys !!! I'm checking with a bloke that knows a bloke that has 45 Dell's sitting on a bus thats not used at moment. I have tune up of old carbs (45 Dell's ) to make it easier .
I will know soon about them !
Craig 44idf are they same stud pattern as Dell's in manifolds ? I have manifolds .
I know webbers more ! then Dell's .
Allan , those are yours to borrow first mate ! Who ever own's them !
Dumone, thanks for looking ,I really need good working ones ,time isn't on myside. Jeff or your bro ?
Thanks , will post pics of melted carb .馃檨
Craig Torrens 路
So do you need the 44idfs ?
hellbugged 路
Pete.....and possibly Alan if your snooping here:kiss
36 dellortos(on manifolds), 40 dellortos and ???idfs(on manifolds).all doin nuthin this September.......even if you just need the mannies馃槑
Dak-A-Tak 路
Guys I havn't thought much more about this (carbs) working on yellow car and Dyno Mania Day .
I have to talk to a couple people ,about a few things !
Thanks for the offers !
vassy66T1 路
Pete,
When the dyno day is over pop me an e-mail as I have a brand new set of 45 dells doing nothing currently on my 66 beetle as it is off the road. I am just on the southside of Brisvegas (Springfield).
nottingham@theoffice.com.au
cya
Marcus
馃檪
