Kingston, Logan City 4114
Ask if you are chasing anything,I might have it.Just send a U2U.
I have parts for a 1970 beetle – guards $10.00 each + other parts from a beetle I stripped. Rear cut and panels cut out of side under windows.I also have other parts for pre 68 beetle e.g. 2 front guards will need painting probably. They are white with small amounts of rust around the headlight openings. Nothing that can’t be fixed $10.00 each. Rear Seat for beetle, good condition, red, top has small split on top part and small part of beading has come off. Bottom part has small tears around bottom of frame near floor. Came out of a 1966 model. $20.00. Fuel tank, probably mid 60's bought for a project but no longer needed. Has fuel sender unit- I had it working but connections probably need good cleanup, maybe when back in fuel might work ok? $20.00. I have other bits and pieces. 1200 motor not complete, will seperate heads,case, tinware etc
Oil Cooler - this was on my type 1 when I got it, mounted up under rear parcel tray. I don't need it. $25.00
[ Edited on 15-6-07 by stevosky ]
stevosky ·
