Aussieveedubbers 路 Non-VW Engine Conversions
show those exhaust pics...
https://forums.aussieveedubbers.com/threads/63231/show-those-exhaust-pics
72RSbug 路
will be making an exhaust for mij EJ20TT this week but it'll be a very tight fit with the IRS trailing arms and k盲fer cup brace in the way.
Post those pics for inspiration guys... 馃檪
1303 路
http://images.thesamba.com/vw/gallery/pix/224248.jpg
72RSbug 路
nice, keep them coming...馃檪
@ 1303, you flipped over the water manifold I assume?
That's a big disadvantage with the TT's , not enough room to flip the manifold so it's water pipes on both sides + exhaust pipes on as wel with the 2 turbo's
gerrelt 路
For what it's worth, I build one for an Alfa Romeo engine:
(the picture makes it look better, btw)
Here is how I build it:Link
It takes a lot of cutting, fitting, test-installs en scratching your head while lying under your car...馃お
1303 路
72RSBUG,
No i didnt flip the manifold the coolant line runs just behind (you can just see it through the factory hole that mounts the factory Z or sway bar)the steel in the inner guard and then follows the line of the inner guard and exits at the torsion tube about 3 inches inwards from the spring plate retainer.
here is a better pic http://images.thesamba.com/vw/gallery/pix/224403.jpg
There is more room than you think back there.
Paul
[ Edited on 19-6-2007 by 1303 ]
72RSbug 路
anybody else want to share some pics...?
reub 路
Here you go....my 3" fully polished s/s setup with custom fabricated 3" straight through muffler....
72RSbug 路
that one looks really nice 馃檪
Anyone still using the cat in their exhaust setups?
If I use the stock ECU from my TT engine, can I run it without that cat and just put the sensor in the open exhaust pipe?
subaruboxer 路
Yes that should work fine!
I had exhausts with and without the cat and it worked just fine. But mine is no Turbo conversion. Just the EJ 22!
But, as you can see above, Reub is not using a cat, either!
[ Edited on 22-6-2007 by subaruboxer ]
reub 路
Under new guidelines I'd have to run a cat to comply but my car was trated as a modified 1968 beetle that didn't have to comply with emissions....
72RSbug 路
Mine is registered as "oldtimer" here in Belgium.
Only thing I have to worry about is the brakes and emissions being O.K.
robertocarlos 路
Hi,
Just following up on 72RSBug's original question, are there any other photos of exhaust systems used to match EJ20TT engines in Beetles? I've searched Google and this site and have only found photos of the downpipes coming from the turbos (mainly those posted by 72RSBug). What I'm really looking for is how the two down pipes are joined and how the rest of the exhaust system is routed ie photos from underneath the car. Any help would be greatly appreciated.
hotdog 路
I used the cat that came with the halfcut
Joel 路
geez your poor starter solenoid must get abit toasty
1303Steve 路
I've never seen a EJ20TT fitted to a bug.
Joel 路
they look like a tight fit
1303Steve 路
Hi Joel
Wow that is tight, who owns that.
Joel 路
hey Steve its 72RSbug that started this thread's car
ian.mezz 路
boof [ matt] had one of those motors in something i saw at his place.
http://forums.aussieveedubbers.com/viewtopic.php?tid=59466&page=1#pid585226
colonel mustard 路
dave has a 20tt sitting in his garage...
robertocarlos 路
Thanks for the picture Joel. I was actually hoping for a photo from underneath ie how the down pipes have been joined, where the muffler and where the exhaust dumps to. Cheers.
Joel 路
I've been trying to find a good one of that
i was gonna put the EJ20TT in mine but everyone in the subi world has warned me against it or say convert to single turbo
robertocarlos 路
Yeah I've heard all of that but I'll press anyway...if anything I'll let future Rob sort that one out...lol.
pete wood 路
the twin (smaller) turboes are intended have a quicker spool up time for better response, but really, with a good ballbearing turbo, you just don't need them these days. It's just subaru factory tightness that would stop them using ballbearing turboes too. If you want the best combo, strap on a supercharger for the bottom end that switch over to the turbo half way up the rev range. Lancia did it with a rally car in the 80s with excellent success. A few companies also offered a kit for the supercharged MR2 that did the same.
