Are you talking about splitting the case??
or bolt on.
Decent fully merged header - 1.4 rockers there are a few things
kombiute ·
Thank you, for the info.
Bizarre, thank you for the link, great info, if I crack the case, what sort of Cam and crank would you suggest.
Thanks again
Ahh.... here it all gets hard.
First
1) How fast
2) how many $$$ do you want to waste
If you change cam you will need betted head to benefit and you need better etc etc
A Counterweighted crank is needed if you are going to spin more than 5k revs.
You need a fairly good motor to do that
Cam choice is difficult as it affects so many other things.
A mild cam V Force AP2, Engle 110, Web Cam 118 will work fine with stock heads.
Ask more questions
kombiute ·
Thanks again Bizarre,
I have owened my 71 DC Ute for nearly 10 Years and plan to hold onto it for much longer. My Case has cracked, and I'm in the planning stages of the new motor, but I'm going to have to act pretty quick.
-I have $3000 to throw at it.
-Surf plently, and the ute takes us up and down the coast on regular trips, so I want reliability with punch
I'm in 2 minds.
1. Purchase a new stock 1600 bottom end for $1900 and do the basic mods you kindly have suggested on the link, with my webber 40's
or
2. Purchase a alloy block and all the bits and pieces from scratch, but I need help with the pieces can you help? I can not do the assembly myself but I have given indicative quotes of $700 to assemble
Any additional advise would be greatly appreciated,
barls ·
if you fill in your location someone may be near you to help
kombiute ·
Thanks,
I'm in Kingsford in East Sydney, have you a business?
If you cant do assembly yourself i would maybe stay away from Webers.
Webers are easily jetted but it does take time and "some" understanding
An easier option may be what i have
A 1916 (or 1776) with a stock carb and header.
Nice and simple - Would only cost say $500 - $750 ($250 machining and $250 extra for stock pistons and cylinders over stock cost)
New cases are $700ish.
Cam $150ish
Crank $50 for cleaning yours up to $500 for a new counterweighted.
P&C's $750 for 94's (1916)
Heads $250 to clean up yours to $1000
assembly $700
Adds up doesnt it
barls ·
i use to live out that way when i first came to sydney but that was 5 years ago. my old man has a shop up in taree. there are a couple of others here in sydney that may be able to help you richard at vforce might be one
kombiute wrote:Thanks,
No - but i drink a lot with Richard at V Force at Mortlake (Concord way)
Either pop over some time (late arvos are better - even Fridays - more time to "chat" ) or call him, 0408 991 247 or 9743 1247
Richard as some stuff laying round that he may be able to help you with
Barry
Bizarre wrote:If you change cam you will need betted head to benefit and you need better etc etc
Standard heads are fine with cam upgrades. Plenty of hypo motors using standard unmodified 040 heads.
And the standard crank is fine to spin to 6200rpm all day every day if the motor is built by the right builder. The forged vw crank is one of the best in the world.:thumb
what he said^^
its mainly standard valve springs that are rev limiters
-Joel
kombiute ·
Hello Craig, Thanks for the info, I'm thinking of getting an Empi Alloy case allready machined for 1776, I will look into getting the forged crank, what sort of Cam would you suggest ? Engle?
As I'm building the motor from scrath ie: purchasing indiviual pieces, can anyone suggest a purchase list? and finally, who would be a suggested builder in the Sydney area?
