So.. my 1916 (twin 44s, 044 heads, engle 120 cam) with std oild cooler and additional remote oil cooler has no flaps/valves installed.
Q. Do I need it? Will the oil over cool keeping in mind that I also have a remote oil cooler too?
I have the flap system from my original engine that I can fit so I can If you'all think its necessary
I think the answer is "if you have it AND it works - fit it"
I have never had a set.
None of my motors have cooked.
Question here -
If the flaps are closed
Where does the air go??
ALL through the oil cooler??
Wouldnt that cool the oil more??
aintgotitmusthaveit ·
Thanks blue 74! (nice name)
As to your questions not sure.
reading off Vw-resource it says ...
"The thermostat and vanes together make for a rapid warm-up (lower engine wear); and the vanes also help guide the cooling air where it is needed most - more to the hotter heads, less to the cooler running cylinders."
Will have to take a look at the system and see where the air is directed.
But thanks for passing on your experiences
mackaymanx ·
Bizarre, yes it would direct extra air at the oil cooler. But wouldn't the oil be bypassing the oil cooler when then engine is cold ?
as above if the reliefe valves are working properly then the oil would be bypassing the oil cooler till hot anyway but as the air for the oil cooler on a doghouse shroud comes off a separate shroud at the back the airflow doesnt rreally change
the extra airflow is actually designed to go the the heater boxes when the flaps are shut for improved heating
