type 3 motor into bay kombi
https://forums.aussieveedubbers.com/threads/6335/type-3-motor-into-bay-kombi
type82e ·
is it difficult to bolt a late type3 motor(with the rear mount to the body) into a bay kombi
marcel
baybuscamperkid ·
its fitticult to put a kombi motor into a t3, so i imagine the opposite is equally difficult. why would u do it anyway?
pyr0 ·
surely it would be cheaper and less difficult to just recondition or get a new engine of the same year model ??
242 ·
If it is a type one upright type motor in the van you can just switch the tin ware and oil cooler over. Should fit no problem.
type82e ·
but how would I bolt the rear engine mount to the type 3 engine?
I have a good type 3 engine and am looking at a kombi with an iffy motor
marcel
geodon ·
I once owned a '61 split SC that had had a caravan type body grafted onto it ( ie a proper motorhome) & type3 twin carb motor. They had done this so the double ded could be mounted transversely. It gave indredible access but you had to re-make the bed after any work!! A rear cross member had been made out of angle iron up to take the rear mount.
242 ·
If it is a late motor there is already an engine brace that has the same holes as on the bay brace just swap over to the Bay brace. An early motor does not have this support, a special pump cover plate is available that has the holes to mount either T3 or T2 support bars.
waltermitty ·
I have the EMPI pump cover mount if you want it , its unused and completet bolts and all or trade $20.Mitchell😎.
0422 802 199
I need kombi rear bits for an IRS in a splitty .
