the throwout bearing tube in a kombi gear box-can it be not used as it is hitting the pressure plate on fitting the motor.
pressure plate is a kennedy stage 4 thing which worked well in
the wagon.-motor is rotary if that helps.appreciate any help.
john
dangerous ·
Remove the ring from the face of the pressure plate.
They ALL come with this plate but it must be removed on slide tube style boxes.
There is a spiro lock clip under there that will allow it to come off.
