Golf headlights on beetle
https://forums.aussieveedubbers.com/threads/63549/golf-headlights-on-beetle
lauzboy ·
Does anyone know if Golf Mk1 headlights will fit a '71 Beetle?
barls ·
are you talking about the mk1 h4 upgrades in particular?
because if you are then the answer is yes ive got them in chaos, and they work brilliantly
bushed ·
i have a set for you
$60 posted with halogen globes or $47 without
pls email if u need pics etc
lauzboy ·
sweet
what do you mean by upgrades tho? i take it theyre some what diferent to originals?
also got any pics
thanks
barls wrote:are you talking about the mk1 h4 upgrades in particular?
76 beetles had them as standard.
shaihulud ·
Morris Mini Minor headlight buckets will fit in the hole with a minimum of fiddling. I've done it to 3 cars so far. They cost about $30 each with sealed beams and you get a good set of lights. You will need to add a coupe of small parking lights.
barls ·
lauzboy wrote:sweet
also got any pics
thanks
this is what im talking about
they bolt in to the tabs that are in the buckets.
lauzboy ·
right ok! you mean the lights fit into the headlight adjusting ring. fair nuf
what im asking is does the Golf Mk1 headlight assembly (ie bucket and light) fit into a beetle. i would prob take it as a yes
barls ·
no the lights bolt on to tabs that are in the bucket, and have a mounting fitted to them ill see if i can find a better photo.
here we go just ignore the writing this is only for example
notice the frame at the back of the light the holes match up with the tabs that are in the stock guard if you look carefully
