[WTB] A couple of small bits..*UPDATE* Pics added..
https://forums.aussieveedubbers.com/threads/63553/wtb-a-couple-of-small-bitsupdate-pics-added
jo_tas ·
Hey
I need two small things for my car ('71 Type 3)
1. An interior light
2. The little steel exhaust U-bend bit that has another seperate smaller pipe coming off it... uhh.. hard to explain lol.. the smaller pipe connects to another pipe that runs up the side of the engine. I think it has something to do with the heater, And theres one on each side of the motor. I need the right hand (driver's) side one.
Thanks,
Josie
[ Edited on 8-7-2007 by jo_tas ]
greedy53 ·
check ebay .au i'm sure i seen one there
Jo
the air pipe is very important on a Type 3 as it is needed to help the cooling of the engine, there are several different sizes and depending on which exhaust system you have, also there is a section of rubber that joins the tubes these are not available anywhere i went searching for some last saturday , so u might have to come up with some thing else
Can you take a pic i have the tube and exhaust area where it was fitted
mackaymanx ·
http://cgi.ebay.com.au/VW-type3-PORSCHE-HELLA-INTERIOR-LIGHT_W0QQitemZ190127515115QQihZ009QQcategoryZ72456QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
jo_tas ·
Thanks guys..
About that exhuast peice.. the cooling part is hooked up, using that flexible pipe stuff.. but the small steel pipe that runs up the side of the engine is open.
I'll get a pic of it this weekend when the engine is out.
Grey 57 ·
Jo, I have a spare interior light if the ebay one doesnt pan out for you.
Dean
PurpleT3 ·
That small tube connects to a thermostat mounted up under the rear seat which allows cold air from the engine fan to be mixed with hot air from the heat exchangers. This is supposed to regulate the temperature of air which enters the passenger compartment. None of mine are connected. I don't know about you, but here in Melbourne we need all the heat we can get in winter. I'm guessing Tassie is the same.
If you aren't looking for a fully original car, you can use some of that corrugated paper/foil tube in place of the U piece. If you have the U piece, make sure you plug the little tube stub that sticks off the side.
As far as I know that little tube has nothing to do with engine cooling, but you don't want it leaking cooling air from the fan shroud.
bushed ·
u have u2u but my lite is cracked now...fell down
chrome nice
6v or 12??
jo_tas ·
Thanks bushed.. already got a light organised.
Purple T3.. the important bits are hooked up (the cooling stuff) using that foil tube stuff just that smaller tube isn't connected (the one that runs up the side of the motor) Would this effect my heater?
PurpleT3 ·
Nope. Will make your heater run a bit hotter.
Actually, I just figured out that with out the pipe attached the mixer box will allow hot air to escape, therefore decreasing the amount of heating you will get into the cabin. I would just block up the little stubs on the thermostat boxes. You will have to lie on your back under the car and follow the heater tubes from the heat exchangers on the engine to where they connect to the car body. Those odd shaped boxes are held on by three screws. Remove the boxes and you will see a little pipe coming from the top. Just block that pipe to keep your heater air in and reinstall the boxes.
[ Edited on 7-7-2007 by PurpleT3 ]
jo_tas ·
Heres a couple of pics of the part i need:
jo_tas ·
**BUMP**
You need the small convelouted tube that runs forward to the heater thermostat and the clamp
Give Vintage a call in Syndey 02-9789-1777 they have in stock
jo_tas ·
Umm no i don't..
I have the tube.. i'm missing the U-Bend peice..
Ok they have both pieces do u have the rubber joiner bit ???
Klaus ·
think I have a few of these will check in the morning. If u need the black plastic boxs under the seats I have about 10 pairs.
jo_tas ·
Thanks, that'd be great. don't need the plastic box things though..
ragtopp ·
Jo!!! Oh no!! I just sold a new old stock interior light three weeks ago. Sorry mate!!! Im going to get a new Notch on the weekend, its a 70 model and cool as. Got a late fasty to wreck with it to, if there is anything else you need. Notch is brown, lowered on wide steel rims painted white, next to no rust and runs sweet as. Found her in launceston.
jo_tas ·
Ooh!! When's it arriving??? I'm there!!! 😉👍
kombimatt ·
Would love to see it Ed.
Haven't heard any more about the notch I was chasing. Your advice cooled my heals somewhat!!!
jonnyb ·
did you get the parts[u-bends] jo ?
jo_tas ·
Nope.. still chasing one..
jonnyb ·
ok I'll throw them into the trailer for the journey down.Will be there 28th in hobart
jonnyb
