swap 50,s doors for 60,s doors
https://forums.aussieveedubbers.com/threads/63557/swap-50s-doors-for-60s-doors
vwsteve ·
Ive got a set of 50,s doors on my baja project and would like to swap them for a pair of early 60,s doors if anyone has them, the 50,s doors are in good condition for age, may have slight rust inside but not bad, the 60,s doors must be in good condition, cheers, steve 0409475131
bushed ·
pre 56 0r later Rexy??
bushed ·
have a 64 drvrs one i will check
do the 50's have widows etc ? or bare pls
vwsteve ·
the doors are 56 or later and complete
bushed ·
taa, will check and consider
anythin else u may wanna have me swap if i only have 1 door... split, KG,beetle, golf t3
email me if u wnat pics
am down Bris soon
vwsteve ·
What have you got in the way of kg parts bushed?
bushed ·
screens, screen chrome ,odds and ends ie tail lite chr
ie intr'r air vent clip some rubbers, horn ring , steer wheel, 1door hinge
set of door stops
set of door catches (custom made from superior than standard material) 1 bonnet gd con
mech bits 36hp box drum to drum, speedo
mate has nos h/light gear and othr bits ie one overrider and bumper bracket flashing nos!
vwsteve ·
give me a call sometime bushed and we could probably sort something out with kg parts, cheers
bushed ·
u2u ur numbur mate
the door is v good btw 65 mod
no glass atmo no qtr no handles that ok?
04212 86423
vwsteve ·
Bushed my number is above, if you only have 1 door and not complete i will probably find doors somewhere else but if you want 50,s doors i will swap for kg parts, cheers
bushed ·
dont need kg bits atmo
maybe door rubs
The drvr door i have is rare ...as statistically about from ca ten drivers doors that get hit 1 passenger door does!
Can complete it 4 u
but sos i did not ring as was on the road earlier.
mY post pafe display is in reverse so now I see ur number below .
talk soon.
I have v.good qtr vents and rubbers as well as door rubs if u need. 6volt!
