Fuel Injection ( For Sale )
https://forums.aussieveedubbers.com/threads/63561/fuel-injection-for-sale
koolkarmakombi ·
Stanley ·
They seem like big injectors...what size engine will it be? and what ECU will you use?
56astro ·
Looks like it will be a very "stock-looking" set-up.
What size motor is it going onto?
using Microtek MT8 putor
Interesting combo....:kissvw54 wrote:it will be 1916 69 x 94
Takhoal ·
Nice looking system there too!
[ Edited on 5-7-2007 by Takhoal ]
Craig have you got any Kadrons ??
pete wood ·
Yes, are you after some?vw54 wrote:well it could be 94 x 69 depends on how you want to say it
pete wood ·
Just a joke really!........hadn't seen a 1916 combo before :P:Pvw54 wrote:why is that Craigie
Boostn ·
should drive very nicely !
I would run bigger injectors though.
you will max them easily.
type3lover ·
I think VK was the first efi in a 3.3l (holden black motor) and then they used the nissan 3.0 motor in the VL.
Just wondering which injectors u used or were they the same? (bosch tan-tops?)
Cheers! Toby 👍
If you need to borrow a set just let me know :thumbvw54 wrote:have u gota spare set of Kadrons ???
Nick they work out at 550ccs per injector i thought it would be an over kill ??I would run bigger injectors though.
Dasdubber ·
hopefully i will have the engine ready to fit in the next few weeks, then comes the fun part
Dasdubber ·
Also sorry if you have covered it already but is there going to be a swirl pot/surge tank anywhere? Finally can you give some info re. what type of pump is that you are using (is it a low pressure pump for the return....or if it is a high pressure efi pump then why the low pressure filter?)
Sorry for all the questions!
Alan
The feed line from tank to pump is 1/2 or 13mm the main feed and return lines to n from engine are rubber 5/16 or 8mm
No i am not using a surge tank a few people have done it this way and providing your not cornering at 100klms per hour or racing it should be good for street also must remember not to go below 1/4 tank
The pump is off a VL Commondore 3.0 Litre Fuel Injection so it will be able to feed a 2 Litre engine no probs its HP or the main or only fuel pump
The filter is there to remove any junk from the tank and is a heavy duty plastic type that will handle the suction from the pump
I have another HP filter on the feed line prior to the fuel rails, which will be located under the rear firewall and is of metal construction
no probs with the questions
vintage ·
jenz58 ·
Euro_67 ·
yeah dont know how it will feel the origional spring on the Throttle body looks pretty stiff so may have to cut it a bit
yeah good job always allow a few hours in the day to do some small jobs for yourself LOL
I will be fitting to the Orange Smoothieeeee
http://forums.aussieveedubbers.com/viewtopic.php?tid=4762&page=1#pid248566
jenz58 ·
Took 4 minutes lol
So is the Orange Smoothie off the road for a bit while tweak a few things?
[ Edited on 13-8-2007 by vw54 ]
StenGuns ·
lulu94 ·
gives me ideas for Danielles beetle - only the inlet could have a bit of a plenum in the middle and four individual runners all the way, similar to the factory type.
hmmm I'm still logged on as Danielle.. oops.
Have primed the oil system and have run the fuel pump is all looks good for a start next week
[ Edited on 11-9-2007 by vw54 ]
56astro ·
Wish I was as quick as you getting it all together.
How does it run?
Is the tuning finished?
It fired up pretty easy
now the tuning process begins
I wouldnt say quick I started planning about 3 years ago and collecting all the bits n pieces making clamps and replacing the gearbox fitting the fuel lines etc etcWish I was as quick as you getting it all together.
Ive had the car off the road for nearly 10 months Its the only way to do it
big thanks to Leigh sorting out the Microtech wiring and doing the initial start up and programing on the handset
thought it may have been a pain in the bum but using a bit of rubber tube pushed on the end of the plug and screwed in by hand then tightened
StenGuns ·
dangerous ·
How about a centrifugal blower?
yes i have set it so it woukld be an easy conversion to fit a small pair pump in behind the back seat and push through the firewall with a 2 inch tube
I have to re restore my 56 sunroof Oval next thats the next big project after this
opps forgot i have to fit the old school spped stuff to my 65 in between too many jobs
StenGuns ·
heres some of the finished pics for you
Westi made me a nice tube
56astro ·
the engine is running quite good and happy wil no oil leaks, will be fitting an external cooler over xmas with a thermostat I already have the case drilled for full flow its currently running about 3 meters of hose under the pan of the car
Once again thanks to Boris, Leigh, Brad ( westie) Ian ( Pirtek ) and the many hours with the air grinder from Qantas
anyone interested in the components i used i have a spread sheet with cost and address etc etc
urban_myth ·
havent had time to run the 1/4 mile as yet but will be doing so in the new year
StenGuns ·
The pressure will be equal, it will attract some heat to the fuel once it gets to the other side, but for the cars intended use they work fine, EFI bays, Type 3s and T3s and even Subaru's use the same set-up.
no problems with any sort of fuel starvation at all
i did make the rail 19mm ID so theres a bit of fuel reserve there i used the stainless flex tubing on the cross over line so theres some heat protection there and with the raiis and injectors up n away from the mainifolds theres no direct heat only the radiated heat from the engine
Ideally i suspose you should split the line to both sides of the engine and then return to the center and tank so as to make the fuel path all equal distances from the pump etc etc but the regulator maintains the system at approx 45lb and equals all that out it would be diferent in a bigger horse powered engine i would imigine
just did a fuel MPG the other week
its running on Unleaded no pinging and getting 25.7 Mpg or 9.1 liter / 100 not bad i think no surge tanks or other complicated multipal throttle bodies and the like
use the KISS method keep it simple stupid
ElusiveStranger ·
Keep it up 🙂
marty_08 ·
Was wondering were you tapped ur head for the head temp sensor for the microtech ECU. I notice u've got the MT8.
I have a 10 - the one with the ignition control, and need to mount my bosch head temp sensor into a set of CB performance 044 heads. Just curious as to how you did it so i don't need to re-invent things!!! 🤓
Marty
I tried taking a pic the other day of my sensor location but couldnt get it
its drill n tapped into the exhaust port area so it get hot pretty quick
Its a single wire type from VW from memory
hers a pic of the left hand side wiring it goes through the tin ware to the sensor
will try n get a pic tomorrow
marty_08 ·
Is that on the drivers side of the engine?? Looks to be near cylinder #2???
Would love to see the other pic. 😵
Bug_racer ·
Injectors are way too big . I was running 580s in the S3 when it made 330whp and they were about 90% duty cylce . Your better off getting 280s off a golf gti if you plane on going turbo or even 200cc off a VR6 if your keeping it N/A . Also the newer injectors have a better spray pattern than the earlier ones .
I would also run heatshielding on the fuel rails . if your going turbo the rails will prob need to be replaced as will fuel pump .
What fuel pressure are you running ?
Is it wideband or narrowband ?
Is it running a MAP sensor or TPS only ?
Where abouts is the temperature sender ?
fuel pressure is 45lbs
it runs TPS then flicks over to MAP
the temp sensor is in the head
riggsbie ·
I am new to this forum and searched and found your EFI project, fascinating !!
I want to do something similar but am struggling to find much information on it... Any tips ?
I was thinking along the lines of a Ford EDIS ignition system hooked upto a Megasquirt, not even thought about fuel rails and injectors.....
Any advice would be appreciate.
Riggsy
REVBOB ·
I just found this forum today and it sounds great. I have a '71 Ghia with my home built FI on a 2276cc NA engine. I used a 52mm TB from a '87 Dodge van 3L v6, CB FI end manifolds with my center section. CB fuel rails with 3/8" steel hard lines to the 20lb injectors. I run 40psi at the injectors. I installed two new 3/8" steel fuel lines through the tunnel with a pre pump filter up front and the HP filter up by the starter. I have EDIS ignition with Megasquirt MS2. I only have about 100 miles on the car so far but performance is unbelievable!! Now if I can figure out how to send some photos I will and also happy tp answer any questions. I know I had a lot of them.
Good to find you guys from down under 🙂
Bob
yes please send us some pics its good to other ideas
I tried to make mine look like a stock system
Sorry i havent answered you sooner just found your remarks you posted while i was in UK on holidays and have sent Email to you
vw40hp ·
hulbyw ·
hulbyw ·
karmann141 ·
How about you let everyone the price?
The set is For Sale minus the Manifold
Original cost to build was $5000.00
for Sale $3000.00 or ONO
Sydney
$200.00 ONO
Sydney
