Wanted Air flow meter for fuel injected 76
https://forums.aussieveedubbers.com/threads/63562/wanted-air-flow-meter-for-fuel-injected-76
matthew74 ·
Hi I need one of these. Can somewon help out
Matthew
koolkarmakombi ·
Try the US, Samba or shoptalkforums
iirc not imported like that into oz. Wiser minds will know for sure
Some local Kombis in 76 had L Jetronic EFI, worked great. Good luck finding a airflow meter.
pod ·
can these be recoed ,and didnt the vk commodore have L-jetronic efi,just a thought❓❓
yeah try looking at Volvo, Holden, Ford XE-XF, BMW etc for a possible match. There are different size airflow meters for different size engines - HTH
matthew74 ·
Thanks for the ideas!
Will check out bosch web site maybe can match part no's with some other make.
The sliding resistor is not working I will pull it apart and see if I can get it to resist 🙂
cheers and thanks again
Matthew
matthew74 wrote:Thanks for the ideas!
Matthew
That is a common problem with some 'vane' type air flow meters, and throttle angle sensors on things like EA Falcons. Try cleaning it...
Tim Meier ·
I have a working one for a beetle with fuel injection. I think it was from a 75-76.
The part number is 0 280 200 006. It has 6 pins (I think some had 7)
I am not 100% sure that it is compatible. It is a funny business with the FI systems because a lot of the parts are interchangable. For instance this AFM works fine in my bug which is a 78.
This site may help (or confuse you):
http://www.ratwell.com/technical/FISwap.html
I am in Melbourne but my parents are flying to Brisbane tomorrow evening so be quick to exclude shipping costs!
PH 0404836246
Tim
matthew74 ·
Tim Meier wrote:I have a working one for a beetle with fuel injection. I think it was from a 75-76.
PH 0404836246
Tim
Thanks for the offer. Mine is a 7 pin so don't know if it is compatable. As soon as I can get a spare half hour I will pull it off and and see if I can repair it.
Thanks for the link also.
cheers Matthew
