gave the beetle a punch around a corner and snapped my accellerator cable! need a new one!!!
xornge666x ·
mercwreck/volksparts 22 Lanyon in Dandy.... now that BME (MrBug) is no longer...
Hi Damien,
did the cable break near the carburetor??
oval TOFU ·
yeh it did Lee..
You got it sorted yet Damo?
killakornkobb ·
yeah lee just the end broke off i patched it up w/ the clamp that holds the cable to the carby, and a paperclip!!! its getting me to and from work.. but i dont want to tempt fate really🙂
*did* ·
hey damo, i'll have a look for you tonight or tomorrow night, may have one somewhere
wacked1 ·
hi mate i did the same thing on my 1500 beetle about 6 manoth ago and mine has a 1600tp with twin webbers on it . i went to binnings and got some of that steel cable it does the trick. i punch mine all the time and have not had 1 problem yet.
xornge666x ·
a new accel cable is maybe $5, I used to buy em for $2...
I would suggest buying the right part for the job, and a spare for next time...
A company in the USA sells throttle cables that don't break...
I tried to buy them once but they didn't want to know anyone outside the USA....
also made unbreakable clutch cables....
the reason the accelerator cable breaks is the cable flexes all the time next to the crimped on piece of metal...
the cables would last longer if the end bit wasn't there....
Hertz ·
68AutoBug wrote:A company in the USA sells throttle cables that don't break...
Good tip then?
xornge666x ·
with everything setup properly, it should not have much flex there anyway...
the early cables are solid not braided, and last for years... they do not flex at the end at all.
often with twin carb linkages, or the horrible empi single centre mount idf manifolds etc the cable gets pulled out of line.
also need to make sure the bowden tube is in place between the rear of the pan and the tube that goes through the fan housing.
