Hi all, with approx. three weeks before i leave for Canada to build jet engines for 3 months, i have decided to sell a few things. First up is a 1600cc type 3 engine and parts, the engine is only a shortblock, the case was thoroughly cleaned and crack tested by me at my work, no cracks were found and all dimensions are within tolerance, i had the case align bored 0.020"/0.50mm, the crank and rods were reground 0.010"/0.25mm by Crankshaft engineering and balanced, the rods were balanced end to end and new small end bushings fitted the pistons were also balanced. The cam i used is a Fuel efficient series from CB Performance with matching lifters, pistons and cylinders are new 85.5mm. Cylinder heads are also brand new original VW castings with 37x 33mm valves. I would like $1500 for the engine in short block form. Secondly i have a Whiteline front adjustable sway bar 22mm unit stock width, never used only fitted to my floorpan for mock up, $200 plus postage. Third i have a new 12 generator volt generator $250 plus postage. Please contact me via U2U or ring after 4pm please. I am in north Brisbane. Some photo's for you. Cheers Damo. Ph#0405464872
[ Edited on 22-7-2007 by 66deluxe ]
66deluxe ·
