FRONT BEAM URETHANE BUSHINGS
https://forums.aussieveedubbers.com/threads/63714/front-beam-urethane-bushings
sdat ·
Has anybody used those Bugpack bushings on their front beam? What are they like ? Do they replace the needle bearings and bushes? ie. remove all bearings and bushes and replace with the urethane insert that slides into the front beam tubes, is this correct?
xornge666x ·
Yes, they replace the inner and outer bearings in the beam.
Mixed reports on them, but I think they are fine, though need to be chaged a lot more than the factory bearings do....
and need to keep them greased, or drill the holes through where the grease nipples are and use a urethane friendly grease on the arms.
