1600TP in a KG.
Last time I did the clutch I re-used the thrust bearing. Unlike the old carbon ones they last forever BUT u need to check the spigots for wear AND the fricken holes on the ends for the clips. I didn't & paid the prce! A clip fell off & the bearing fell off the forks! Why? Wear on the spigot shaft & an oval hole on the end. It had obviously been rattling. Ah well! Ur never too old to learn they say. Funnier still, I thought it was the cable (at the pedal end) but I didn't spot the problem untill I took it out-only after I used bolt-cutters to chop it at the eng end to "facilitate" the removal of a perfectly good cable!
Scheiss!!
Fortunately, the forks look OK.
[ Edited on 14-7-2007 by geodon ]
geodon 路
