I have a 2599cc type 4 engine that is complete and assembled and has not been started . 78mm scat forged crank with type 1 main jnls , CB H beam conrods in 5.5'' , 103mm JE piston and barrel kit , Web-cam 86 b with straight cut gears , scat lube-a-lobe lifters , forged flywheel to suit 200mm clutch , pauter super pro heads with 54mm x 45 mm titanium valves - vasco tripple springs - crower retainers , pauter 1.4 roller rockers , pauter race pushrod tubes , autocraft dual tapered pushrods , type 1 upright conversion kit , intake manifolds to suit IDA carbs , 4 exaught flanges and copper gaskets , for the bargain price of $ 9500 . I also have a set of 48mm IDA carbs that I will let go for an extra $ 1000 , ROD , 02-42729920.
RodPenrose ·
I would like to sell this engine and will consider all reasonable offers . This engine will prouuce well over 220 hp and is not really a street engine with a compression ratio of 10.5:1 . I would also dyno tune the engine with a spec sheet for the potential buyer , thanks ROD , 02-42729920 .
Golde60 ·
is this thing still around or sold by now?
bond ·
call rod.
dangerous ·
That is about 1/3 of what it would cost to build.
You may want some bigger carbs (or throttle bodies) though!
RodPenrose ·
This engine is still available and I am open to offers as I need the space for something bigger and better . This is a race only engine unless you have a good supply of hi-octane fuel for the street , ROD , 02-42729920 .
dangerous ·
This should make as much power as my engine.
Ecellent value.
