Aussieveedubbers 路 Tech Talk
6v and stereo?
https://forums.aussieveedubbers.com/threads/63779/6v-and-stereo
56veedub 路
Ok so is there any way to get a bit of a stereo system happening on 6v or am I doomed to a life of silence :p. Tried searching the site but came up with nothing, but if I missed it a point in the right direction would be good
pod 路
you need a 6v to 12v converter ,but they will only run a basic stereo馃檪
56veedub 路
hmm thats what i figured, bugger....well then my next question I suppose is then whats involved in converting a totally stock 56 dub to 12v 馃お
pod 路
generator ,genny stand ,bulbs,regulator ,battery a step down for the wiper voltage,and if you are running your semaphores you have to do something with them as well, i think thats it:thumb
BUGBOY 路
first i'd look at what power the radio you want requires?
a 6 volt 12 volt covertor might do the job.
second if your running a 36hp motor you need a 12 volt gen.
They are not cheap and hard to find.
They are from 356 porche or off early industrial motors.
Then you need to change globes , wipers etc etc.
not a cheap way to go but it is a good one as you get better lights etc.
If you want more info drop me a u2u as i have converted a few before.
vw54 路
as per above the 36hp engine has a fixed Generator stand which can not be changed
What engine are you running
If your wanting to run a DOOOFF DOOFFF stereo system then you may need an Alternator
greedy53 路
you could run 2 6 volt batteries and run a battery switch than you will have more power than you will ever use and u can put a 12 volt radio in by using the batteries i tandem the switch will keep the 2 seperate so the 6 volt is ok and with 2 wires you can have 12 volt in 1 place
camando 路
can you run the batteries in parrallel off the gen then series to the radio?
does this short?
(havnt tried it)
