heads
https://forums.aussieveedubbers.com/threads/64113/heads
DubCrazy ·
One of the heads on my beetle has had a rather intresting repair done on the exhaust when it joins to the head. what i need to know is what would be the best way to fix? its the one on the front and the bottom stud thats missing(it had a selftaping bolt ramed in). Can i get someone to weld it up and retap a stud into it? or helicoil? another solution? i am not to worried if its perfect as its a baja and covered in mud most of the time...
steff................
Special Air Service ·
Asmlong as the self tapping bolt has not enlarged the hole more than is required for a helicoil then a helicoil will be the easiest solution in my opinion.
Someone else may be able to let you know what size hole an M8 helicoil requires to be effective.
Brendan
DubCrazy ·
a bit to big, the old stud was drilled out and this selftapper wound in...
steff
1500S ·
Can you tap the hole out to a standard M10 x 1.5 ? The hole should be 8.5 diameter for this. Have a stepped stud made to suit, that is, M8 one end and M10 the other. Can help if you need a stud. Let me know.
DH
Matt Ryan ·
DubCrazy,
You'd be mad if you don't take up 1500S's offer to make you a replacement stud. I wish I'd known him a couple of years ago, I had the same problem & an engineering shop charged me $40 to make me a stepped stud. I needed to get back on the road & didn't have much choice other than to cough up.
Regards,
Matt.
