new 1916cc engine
https://forums.aussieveedubbers.com/threads/64150/new-1916cc-engine
RodPenrose ·
I have another 1916cc engine that has just been finished that includes the following specs ,
magnesium engine case
69mm crank
std conrods
engle w100 cam with aluminium gear
mahle piston/barrel kit
lightened flywheel
aluminium pushrods
043 mexican heads
all new bearings
009 dizzy
oil pump with filter
scat lifters
std pushrod tubes
crank install kit
case install kit
cam plug
fuel pump/rod/spacer
aluminium bolt on rocker covers
scat solid rocker kit
swivel feet adjusters
doghouse cooler
chrome dipstick
oil pressure switch
bosch w7ac spark plugs
alternator stand
aluminium degree pulley/chrome bolt
bearing dowells
dizzy drive
cro-moly head stud kit
and a compression ratio of 8.02:1
this engine is 100% brand new and has been built using no 2nd hand or reconditioned components .This will suit any type 1 , early type 2 or type 3 car . Total price of this engine is $ 3650 . Delivery can be arranged Aust. wide , thanks ROD , 02-42729920 .
[ Edited on 5/8/2007 by RodPenrose ]
3toes ·
You have U2U.
vwkg ·
I don't think that he comes around here much. Most people are told just to ring him on the number if genuinely interested.
3toes ·
We did ring him and he asked us to send him a U2U as he doesn't have the time to talk on the phone.
Chris
good deal go 4 it
u just have to come up with the tin ware
RodPenrose ·
I can also supply a 12 piece tinware kit in 36 hp style , with or without heaters in black for $ 300 . I can also complete the deal and make it a turn key engine if you are interested , ROD , 02-42729920 .
engle 100 cam and low compression.......what a waist of a 1916.
humpty ·
Craig Torrens wrote:engle 100 cam and low compression.......what a waist of a 1916.
Huh, now thats funny.... I thought you said it was low compression?!.... That would make a very nice torquey street motor IMHO.... My 1776 runs 7.5-1 and makes nearly 120hp at the wheels on PULP... Sure my 044's are Shimo specials, but in anycase, the 1916 would make a good intro donk for someone...
