36hp oil leak
https://forums.aussieveedubbers.com/threads/64239/36hp-oil-leak
57oval ·
I have a oil leak behind the crank pulley. Is there an oil seal, if so is it easy to replace, thanks.
no there is no oil seal..................are you sure its coming from there?
theres an oil flinger inside the engine which you have to pull the motor apart to replace if its not in there
