getting a ej20h-tt engine. i know its heard many times on here. but as a newbie, i dont see any links or websites showing or listing what needs to be takin off the motor for a vw bug swap. i know power steering components are to be pulled off the motor but dont know about other stuff. anybody have a link, list or etc? cheers
72RSbug ·
power steering goes off, the AC pump also (unless you plan on using it), the charcoal canister ( black cylindrical thing near the air filter) can go and you can just plug its connecting lines shut.
Alos directly above the flywheel there are 2 hard lines for the Subaru's heater which you need to connect together if you don't use them ( don't block them).
supa74 ·
hey i think i came across your car domain website last night thru my searching. it was showing pics but didn't know what all needed to be takin off. thanks for the list and for that website, not many around to go by. cheers:thumb
Baja Wes ·
if your in Australia you need to keep the charcoal cannister to get it legal.
seagull ·
you would be best to make this motor a single turbo
are your injectors yellow ? or gray ?
supa74 ·
had'nt brought it yet but fixing to in a day or two.
heard you can wire both turbos together n the ecu reads it as one turbo.. a guy said thats how he does his. claims it goes all the way to redline like that but he uses alcohol with his.
