Aussieveedubbers · CB Tech Info
ZF Diff
https://forums.aussieveedubbers.com/threads/64273/zf-diff
BUGBOY ·
Is there any way to check a country buggy has a ZF diff?
If the car is not running etc do the diffs act like other locker type diffs with both wheels off the ground rotating the same direction?
Where other Volkswagens fitted with these diffs?
[ Edited on 10-8-2007 by BUGBOY ]
The easy way is to drain the oil and have a look through the drain hole.
USCB ·
Craig,
The oil fill plug will be special on a ZF diff tranny. Special oil was used.
Check this link on the Samba Gallery under ZF search.
http://www.thesamba.com/vw/forum/album_search.php?mode=results
Erich
"" Where other Volkswagens fitted with these diffs? ""
yeah the 181s had them in limited numbers
