My 1600 Beetle flywheel has a badly chewed ring gear & I need a replacement. I don't have much to spend, so I'm hoping someone who's going to Sawtell might have one they can bring with them as I imagine postage would be a real killer.
Matt.
[ Edited on 12-8-2007 by Matt Ryan ]
hellbugged ·
assuming a o'ring style seal?
[ Edited on 12-8-07 by dumone ]
Matt Ryan ·
Not sure Daimo, haven't had the flywheel off yet, engine still in car (just getting the parts together). At the moment I only drive it locally & spend a lot of time looking for hills to park on.
Currently has 6volt starter & flywheel running on a 12 volt system. I'm glad you replied, I was told by previous owner that Mark did the engine swap & 12v conversion many years ago in the Nambucca workshop.
Engine no. is AB 943669. I think it might have started life as a 1300 twin port but is 1600 now.
Regards,
Matt.
[ Edited on 13-8-2007 by Matt Ryan ]
hellbugged ·
ooorkay, will see what i can dig up
Matt Ryan ·
Thanks mate, see you "up the road" at Sawtell.
Matt.
hellbugged ·
don't happen to have motor out at the moment?
a tooth count on the flywheel would help
Matt Ryan ·
No Daimo sorry,
I'm still driving it occasionally (when I can find a hill to park on)
Forgot to mention that it is a dual relief case too.
Matt.
RISKY_VW ·
ill have a look in the shed as i think i have a spare
shite yours must be bad are you sure it's no starter
[ Edited on 13-8-2007 by RISKY_VW ]
maybe its stuffed because you're currently running a 12volt flywheel with a 6 volt starter..............just a thought.👍......................I've seen it done before!
Matt Ryan ·
Yeah Craig, it had crossed my mind but I'm not sure if its been touched since Mark Pell did the engine swap & conversion, way back. You never know, some mug mechanic might have replaced the starter based on the year model of the car, rather than the engine in it. I guess I'll just have to wait until I can get it out & pull it apart.
Daimo,
I think I should leave this until I've got the engine out & flywheel off, which isn't likely for about a month. I'll get in touch then & If you're able to help, I can always do a quick run up to Valla in my rice burner.
RISKY_VW
Thanks for the offer but I'm putting it all on hold until I know exactly what I need.
Regards,
Matt.
hellbugged ·
yeah Matt,
i was kinda working up to what Craig said.......no problems tho, we have flywheels, starters and the adapter bushe to run a 12v starter in 6v gearbox when your ready
