091 question
https://forums.aussieveedubbers.com/threads/64305/091-question
555bug ·
Hey I have a question, the 091 gearbox has a top mount and a front. Now I have the brackets but apparently the rubbers are nowhere to be found, any ideas? next the front mount has two forks does anyone have a picture of what they plug into?
I am considering using these standard mounts to fit the 091 to a bug, does anyone have any pictures of kombi 2L in bugs and if so whats the best mounting system (must be rubber mounted) that is nice and strong as its Subaru powered.
Cheers Stephen
I think BajaWes has some pictures on his page of a bus box fitted up to a Type 1 pan. The bus mounts on the top of the bell housing are a rubber pad. I'm using the bus mounting bracket and rubber pads as a middle mount for my G50. The front bus mount is a like a horseshoe, with the two ends facing forward and the ends get sandwiched in a steel block.
Bus mounts on my G50,
555bug ·
cheers Steve, I have similar plans but I can't quite visualize the end yet.
hellbugged ·
you want mounts......
http://www.geneberg.com/product_info.php?cPath=351&products_id=1066
have some here for front kombi into bug if you need.....
front mount.......
rear to frame horns.....
ends up like this.......(yes this one has five forward gears😎)
you may get some ideas from here too........
http://forums.aussieveedubbers.com/viewtopic.php?tid=44043&page=2
[ Edited on 12-8-07 by dumone ]
555bug ·
Jeff, could you take a picture of the setup you think would be best and give me an idea of price? You going to Warwick?
Cheers Stephen
hellbugged ·
Damien actually, but yeah "stuff" is Jeffs stash........
yep, coming to Warrick, will discuss set ups with Jeff and find out $$$
you going forward?, up? etc with g'box too?
Daimo
you got U2U......
Yeah ahh,,,, Daimo !!?
That stuff you got stashed looks good.
Think I need some too.
How pricey dude?
Matt
How pricey dude?
Matt
hellbugged ·
not very Matt,
you worked out the U2U thing yet........you've got one😉
