Ground Clearance
https://forums.aussieveedubbers.com/threads/64364/ground-clearance
flat_iv ·
I cut 1 3/4" off a spare oil pan and I have approx. 5" of ground clearance. Still looks liike I will have to be very carefull. How much clearance does everyone else have? That 5" is based in a 74 Ghia, 2.2L and lowered 1 spline in the rear.
GTMac ·
I have about 140mm clearance, standard sump, EJ20T in back of Fasty.
kevo ·
mate i dont have much more clearance with my rover in the back compare to when i had 4 pots pushing me.
Keep in mind thouth that if i do bottom out, my sump is the last thing the ground is going to hit... word of warning hey
pete wood ·
I'd put a bit of 5mm ally plate across the bottom of the motor. it can sit up hard against the bottom of the sump. that way, if you do scrape it on something, the ally will be sacrificial. 😉
baybuscamperkid ·
how are you mounting the engine? the engine mount could be made to come down slightly lower then the sump as protection.
rocknrob ·
I think i have about six feet of clearance...makes oil chang easy!
OZ Towdster ·
Bloody Amatours hahahaha
helmut ·
and
[ Edited on 15-9-2007 by helmut ]
helmut ·
splitscreen best baja
