WTD 4 Stud Type3 rear flanges
https://forums.aussieveedubbers.com/threads/64452/wtd-4-stud-type3-rear-flanges
11CAB ·
Any leads?
Graham
flipflopsurfer ·
If I can find some wide 5 rear drums for my bus, you're welcome to mine.
Vintage have new ones give them a call 02-9789-1777
if u have no luck i have a set here they have the 5x130 porsche pattern drilled in as well as 4x130 but thats not a problem if ur just using standard 4 stud vw
-Joel
The ones from Vintage are blank no stud holes so take yr pick if you want another PCD
dangerous ·
You can turn down a beetle 4 stud drum if you find no type 3 flanges.
This may be the most affordable option.
GASBNR ·
I know I a guy here in mebourne who has a stack of them, I think.
11CAB ·
dangerous wrote:You can turn down a beetle 4 stud drum if you find no type 3 flanges.
The Type3 flanges have a lip on then that I will use to help locate a VN rotor to. I had a look at the 4stud drum and they dont have that lip.
11CAB ·
vw54 wrote:The ones from Vintage are blank no stud holes so take yr pick if you want another PCD
No reply to email, any idea on cost?
they must be busy I just gave them a call 4 u
Undrilled $85 each
