1200 1600 heads And parts kom,type3
https://forums.aussieveedubbers.com/threads/64471/1200-1600-heads-and-parts-komtype3
glider69 ·
Rob
Moorebank 2170
0416020372
I have 70 heads varying problems no valves springs,need new guides mostly single port will sell $10.00 each which is very close to scrap value or the lot $500.00
1800/2000 kombi carbs left sides only complete with manifolds $200.00
6volt gearboxes 3 off $100.00 each
6volt front ends drum to drum $50.00 each
Baja kit 7 piece narrow headlight type $100.00
1600 kombi upright motor tinware of complete $250.00
Wide 5 14'' widened rims with good tyres $100.00
Type 3 rear blinker assemblies good cond and front blinker assemblies Big lenses $150.00
Small type 3 rear lenses only $50.00
Pics up tonight
[ Edited on 20-8-2007 by glider69 ]
LIFE IN THE LOW LANE ·
Can you specify a little more on the "6Volt" gearboxes?? Swing axle? And ratios if you know would be great.
glider69 ·
gearbox's are swing axle the ratiosare as follows
1st 3.60:1
2nd 1.88:1
3rd 1.23:1
4th 0.79:1
Reverse 4.62:1
Final drive 4.43:1
Hope this helps you out the ratio's were taken from my manual which includes 1100,1200,1200A,1300,1500
Rob
bushed ·
split dwn the middle swing axle boxes are for 1100 and early 1200 36hp
later ca 1960 got synchro on first and a tunnel for diff access (side plate boxes)= 6vlt to/incl 67 1300 - another swinger box in 6 volt!!
[ Edited on 21-8-2007 by bushed ]
gavandrob ·
i am intested in the baja kit i am from vic
Rat366 ·
Hey Glider, do you have any front T3 lenses must be hella.
glider69 ·
do you mean fast back wagon type or kombi?
Rob
gavandrob ·
the transport may not be i problem as a frend is comming to Sydney next week
Rat366 ·
glider69 wrote:do you mean fast back wagon type or kombi?
Rob
Sorry, i forgot they made a T3 kombi....
Type 3 Squareback '73 model.
rupewrecht ·
Got a pic of the "Wide 5 14'' widened rims with good tyres $100.00" please?
