What is the spring rate of 24mm T3 IRS rear springs?
https://forums.aussieveedubbers.com/threads/64476/what-is-the-spring-rate-of-24mm-t3-irs-rear-springs
fullnoise ·
Hi,
If anyone has a manual for a Type 3 can you look up the suspension specs for a Type 3 (Wagon I think) with IRS 24mm diameter rear torsion bars and tell me the spring rate?
I want to give this figure to the guys rebuilding my shocks to they can optomize the valving.
Thanks in advance.
CT
i dont think that the rating is mention anywhere
Flintstones ·
CT,
get in contact with Sway-A-Way in the states as they make Torsion bars.
dangerous ·
http://www.proshocks.com/calcs/torsionrate.htm
Diameter is 24mm,
bar length is not overall as mentioned on the link,
and arm length is from wheel centre to tortion centre.
dangerous ·
PS.
use inches.
They are 23.5 mm, the 24 mm ones were on the swing axle models only. M249 is the IRS option
Old Dubber ·
This may help - from Jeff Hibbard - Baja Bugs & Buggies
