Headlights help
https://forums.aussieveedubbers.com/threads/64595/headlights-help
boxofrabbits ·
Ok heres my problem, my lights on my 72 Squareback are on the fritz.
When I turn on my headlights to full they go into the parking light 'mode', the same brightness as they'd be if they were set to the same mode if the ignition was off. From this position I am able to flash my highbeams but they refuse to stay on (I can only flash them).
Does this sound like a problem in the relay? or int he switch?
I'm open to ideas.
Thanks...Nick
rob53 ·
I don't have a squareback, but I have had the exact symptoms on my beetle. In my case, two of the crimp plugs at the switch were touching. Maybe have a look and make sure that it's not the case?
57oval ·
check the earth return from headlight is in good contact with the body, sand area for good earth
ive had that a few times on different bugs ive owned (type 3 and bugs have pretty much the same electrical systems)
everytime it was the headlight switch burning out cos i had 100w bulbs in
added hi and lo relays and never had problem since
expect everyone bitching my lights are too bright
but it may be that the 56wire on the headlight switch has come off too
have a squiz
hth
Joel
