Aussieveedubbers 路 Tech Talk
clutch out = idle drop
https://forums.aussieveedubbers.com/threads/64680/clutch-out-idle-drop
newoldmanx 路
i have a strange problem im in my buggy in neutral with my foot on the clutch when i release the clutch the rpm's drop and the engine sounds like its under load馃槧
is this the
A. gearbox
B. clutch
C. engine
D. other
why??????
BiX 路
There will be some load as i understand it, but should not be enough to give that much of a drop.....How many revs are we talking?
Well not sure exactly, but assuming its only when the clutch is out, has to be either clutch or GB
If it was the egine should be the same no matter what the clutch is doing.
MickH 路
There will be some load on the engine with the clutch engaged (foot off pedal) as the gearbox bits are still turning.How many RPM are we talking about??? What type of oil is in the box? "Thick"/cold oil will cause more of a "drain" on power but it should be minimal. I recall this being asked before....
newoldmanx 路
ok the revs drop about 250rpm (too much for my liking) otherwise the car is fine ie plenty of power no clutch slip no gearbox whine no excessive throw out bearing noise nothing
:bounce馃檯:bounce馃檯:bounce馃檯
yeah mick it was asked b4 (on another forum which is up and running again btw
http://dunebuggyandbajaadventures.freeforums.org/index.php?sid=7707e4f5e1c1a13b1ed43b72bf6ff440) without a definative answer
its just got me stumped
matberry 路
I have seen it once that as you put your foot on the clutch, it pushed the crank (with excessive end float) back which retarded the timing enough to change idle rpm.
Matt :thumb
newoldmanx 路
thanks matt, but its the other way around when i press the clutch to the floor the idle returns to normal
you can't start this car without your foot on the clutch
555bug 路
I'm with Matt, this was happening to my wifes beetle and a strip down revealed a flogged crank. To much end float but in your case and I'd say the timing is out also (corrected when clutch is in). I'd time it up properly and when you push in the clutch the revs should drop. you can also try pulling on the pully you should feel almost zero movement.
Stephen
66deluxe 路
Is this happening with the 2275 roller engine i rebuilt or another engine cause i triple checked all tolerances throughout the build.
matberry 路
Dunno! Check crank end float.As said b4, grab crankshaft and see if end float is excessive. Should hardly move front to rear. If you see or hear much it is probably too much, but it takes heaps to change ignition timing enough to make idle speed change.
Adsman 路
I have heard this same complaint before. I believe the problem was gearbox mainshaft bearings?? or if recently rebuilt maybe not enought clearance?
