36 IDF Webers
https://forums.aussieveedubbers.com/threads/64686/36-idf-webers
64vwmark ·
What are 36 IDF webers like on a type 1 twinport motor?
Would they use the same manifolds as 40 / 44 IDF webers?
What size engine would they be most suitable for?
cram ·
hey Mark
I have a set for a hot 1641 i will build one day for a buggy.
check out:
http://waitresses.servebeer.com:81/vwpage/index.htm
Also do a search on thesamba.com
great carb for up to 2L with stock valve sizes depending on application you just need to rebuild them properly to suit - from all accounts, mark (from the website above) is a really great guy and happy to answer questions.
The have the same bolt pattern as bigger IDFs.
You can really see the difference when you hold up against a 44!
[ Edited on 29-8-2007 by cram ]
i use to have a set
IDF 36's with 32 vents
They were brilliant on a stock 1600 but i thought they struggled a bit on a warm 1776
Maybe i would try again on a 1775 but i wouldnt use on anything bigger
They seemed smooth on the 1600 but just seemed lump / flat spotted on the other motor
vassy66T1 ·
I ran a pair for a couple of years on a 1776 with stock valves and mild cam. They ran beautifully and gave back excellent economy. I ran the motor in a beetle and in a kombi (69 bay) and they were a trouble free run for me. Never tried to run the motor past 5000rpm as I had a stock crank. Good luck :thumb
64vwmark ·
It sounds like they might be worth a shot
64vwmark ·
Anybody wrecking an old Alfa or Fiat? I hear that they used to run the 36 IDF's
mangrovejack38 ·
pair of 36 webers on ebay right now,theyve got 17 hrs to go,8 bids ,$132.00.look under cars bikes boats ,type in weber ,search ,accessories and tuning.cheers.jack
64vwmark ·
Thanks for that Jack
cram ·
They come up on ebay for around $100 a pair.
They will have to modified as per the servebeer website in my previous post.
