Tell me about semi autos
https://forums.aussieveedubbers.com/threads/64779/tell-me-about-semi-autos
Spook ·
I've been offered a 69 semi auto, but I have to admit knowing jack shit about them.
Apparently it was a daily driver til it blew a head & it's been sitting in a shed for 5 years.
I don't follow the semi auto bit though.
Are they a pre select like a bus or centrifugal like a postie bike?
Are they reliable, are parts hard to come by??
BUGBOY ·
Still like a manual sorta thing as you have to select the gear you want.
Just when you grab the shifter it engauges the clutch for you thats all.
They are excellent to drive, never had to work on one but i would say they would only be a problem when you need work done on the gear box.
yeah like a postie bike or old husky. LOL
[ Edited on 3-9-2007 by BUGBOY ]
ctefeh ·
Spook,
Couple of extra things for you.
3 forward speeds (2/3/4 from a manual box) and reverse.
It's also IRS, no swingaxle there!
No clutch pedal, the clutch is actuated via electrical and vacuum circuits. The gearbox has a clutch and a torque converter.
Parts? Depends. Some are no longer available, a lot can be bought second hand, even from the US.
Their biggest problem seems to be their previous owners or mechanics who've never worked on one.
www.vwar.org is the semi-auto register...
Several of us on AVD have SemiAuto's.
If it was the motor that gave up then that's infinitely better than the 'box giving up! The best thing is to have a look at all the vacuum hoses and their condition, then check & sniff the ATF and engine oils. You won't know much more until you get it going....
HTH
Ctefeh
[ Edited on 3/9/2007 by ctefeh ]
Spook ·
I got a 1300 sitting in the carport, so it will run the day after it gets here.
But having said that, I imagine the flywheel is totally different.
ctefeh ·
Spook,
1300TP or SP?
SemiAuto's have a flex plate. Getting them off can be a royal pain. 1300TP will be no good to you.
PS. The oil/ATF pump is semi-auto specific as well as engine specific (1500SP is different from 1600TP).
Ctefeh
Spook ·
The 1300 is just to get it going & it's a single port, I'll rebuild the 1500 that's in it.
Apparently it did slip in 1st.
ctefeh ·
Spook,
I honestly don't know whether a 1500Sp oil pump is the same as a 1300Sp so I'll leave that for someone else.
Slips in first ("L" for Low)? lot's of things can be read into that!
Well, whatever you do, don't take the torque converter off the gearbox! Strap/hold it into it's position.
If you want, shoot me an email to ctefehinoz@hotmail.com and I can send you a scanned copy of the SemiAuto section from a Bentley manual.
Ctefeh
Spook ·
IF I grab it I'll keep that in mind.
Sneaking another real car past the missus is the challenge.
BUGBOY ·
Spook wrote:IF I grab it I'll keep that in mind.
We know you can do it mate! Go for it!
It was a fathers day present was it not? :duh
Spook ·
Tricky enough getting toy cars past her. Not so much that she notices, but the youngest son goes through them regularly. You see the deal is, he gets anything I duplicate, & he"ll go, "when did you get this one dad?".
Then the wife checks.
Pretending 900 kilo of steel isn't there doesn't work.
Spook ·
ctefeh wrote:Spook,
Ctefeh
Things you find when you open your eyes!
Turns out one of the manuals in my collection is a Bentley, with an automatic section.
So thank you kindly for the offer, but apparently I won't need to take you up on it
