problem with battery losing charge. (updated)
https://forums.aussieveedubbers.com/threads/64789/problem-with-battery-losing-charge-updated
Anthiron ·
ok a week or so ago i left my car over night in the pouring rain in a car park and returned the following night to find my battery to be dead, it was so dead it wouldnt even jump start, i bought a new battery and it started fine,
i figured water had created an earth somewhere and had drained my battery.
now a it has done it again, i had to roll start the car after work last night, and now this morning the battery is completely dead again.
last night after i roll started it i put the multi meter (DC) onto the genny and it gave a reading, but when i revved the engine the reading went down, not up.
is this normal?
[ Edited on 4-9-2007 by Anthiron ]
11CAB ·
What was the reading?
To find a drain in your electrical circuit, disconnect your negative battery lead, and hook a test light between the negative lead, and the negative terminal on the battery. If the test light lights up, then there is a drain. Start pulling fuses one at a time until the test light goes out. That is the circuit draining the battery. However, it sounds like your generator isnt charging properly, and you are draining it over a day or two of driving.
13.8-14.2V at the battery is what you are aiming for with the car running at about 2500rpm or so.
MickH ·
Have your wipers parked fully?? What 11CAB said..pull the fuses and check everything out.
Anthiron ·
ok, gotta get a charged battery in there and ill check it out.
Anthiron ·
my genny warning light is hooked up and working, and doesnt come on when im driving.
pod ·
i have the same problem with my 61,so will be watching this too, as it used to happen when it was 6v and still does it now its 12v:vader
Anthiron ·
i think its weird because i havent really changed any wiring and then all of a sudden it happend, and now its happend again. the car has bee fine for like 3 years
Anthiron ·
ok, exchanged my battery.
put the new one in, found the leak (my stereo ceased to work a long time ago when it got full of water and it appears it has been earthing out and draining power)
however im still suss on my genny.
how can i test to see if my generator warning light functions properly?
it comes on when the key is in the on position, so i know that the bulb works, but how do i know that its actually sensing when its charging or not?
what setting should i have my multi meter on when testing the charge of the generator?
should i test from the terminals on top of the genny? or at the battery?
Nicko
Anthiron ·
bump
greedy53 ·
with ya multi meter and car running at 1500 rev you should read 14-14.5 volts that will tell all about ya charging system.
as for a drain a short story my dad rearly drives his beloved ford but he was always charging the battery before a drive,, about once a month so i went and had a look, turns out the radio had a constant positive feed because it was a computer memory and anti theft by pulling the fuse it fixed the drain,. modern equipment in old cars can cause this type of drain so if its new beaware
syncropro ·
With ignition on, engine off, red light is on as you said, then disconnect small blue wire at the voltage regulator and light should go off, if so then light is wired up ok. Reconnect blue wire. ( I'm assuming it has original wiring colours ).
To test if it is charging, connect volmeter across battery, (use 20V scale), with engine revs up a bit you should see min 13.8 volts - max 14.4volts when battery is charged, but may take a while to reach if battery is still low.
Anthiron ·
thanks guys ill have a look tomorrow
Ich fahre ein Kdf ein Tag ·
You want to be careful not to rule out the gennie. Had problem at the weekend with my other car (not vw).
I woke up on Sunday attempted to start the car. Battery flat. try roll starting, battery to flat for that. Jump start from spare battery. Good, check the alternator by measuring voltage at the battery. 14 or so volts good. Works fine for most of the day but car a little sluggish driving along (had been for weeks but thought it was another problem). Around 6 o'clock went out for tea. Turned headlights on and they dim so badly made my 6 volt volksie look good. Parked car at the place having tea. Try to turn car on after tea. Wont start. Ok roll start again. Car roll starts, hope I can get home. Lights are dim again. 1 minute up the road going up a hill car completely stops. The alternator was definetly not charging the car. Call RACT, get towed to auto electrics at 10pm. Not such a good night considering it was my wedding anniversary.
What i learnt from this escapade make sure you test the gennie with heaps of load on it before driving away. So Anthiron turn on your headlights check if you still get around 14 volts if not my guess is the gennie is stuffed.
Anthiron ·
ok thanks for the info dude
kevo ·
VERY INTERESTING!!!
EVER SINCE I BOUGHT MY 76' BUS it has been doing this, sometimesmore than others but if i park it up for more than two weeks it is dead by the time i come back!
S***S me off every time! but i can stioll not find an earth in th system tho,,,
greedy53 ·
i had a ford once and had a elec drain problem for a year turned out to be a leaky relay bloody drove nuts
BiX ·
Could always fit a big kill switch in the cab.
greedy53 ·
one of those big red ones look very racey
kevo ·
yer cool ill get someone to fit one of them!
i think i can get an industrial power shut off swith one from some guys atn work too because all the open pit and underground site vehicles need them.
COOL dat solves that problem!
greedy53 ·
now my mouth is watering that should drive the el natural boys crazy
Anthiron ·
well i think my genny must be ok, i can discconnect the charge wire to the battery when im driving and still run lights etc and drive home so it must be giving out power, and it hasnt happend again since i disconnected the stereo.
thanks for all your help guys.
Nicko
