ok had no dramas with my swingaxle at all, pulled up at shops and shut car down. I returned and started the car, when i went to pull away a loud bang came from the left rear and i lost drive. it sounds like the shaft has snaped and its spinnign freely . when a mate turned up i showed him and he says the left rear wheel is moving forward everytime it clanks. ideas? and if its the shaft snaped or broekn how ever can i replace just that one side? i am planign a irs conversion but not just yet and its my daily driver now as i sold my other car... any pointers would eb great as i need to get this sorted asap..
steff....................
*did* ·
check your brake drums, are the splines still there? if not, there's your problem. it happens
DubCrazy ·
ok started to pull it down and it appears to have broken the axle at the gearbox end. Now from memory on a swing axle they have a flat section at the end that slides inbetween two half cirlce rods and that where it does from a flat paddle section to the tube is the weakest point and is prone to breaking. so fingers crossed when pull the rest down this is the problem ...
steff........
Anthiron ·
wow thats pretty crazy to break an axle
yeah you have a spade end that sits in between two fulcrum plates in the side of the diff.
if it is the axle that is broken u can undo the circlip and take out the thrust washing and then the axle will slide out, there should be a colour painted on your axle, i beleive u need to get an axle with the same colour mark to match your fulcrum plates, then (being very careful with the fulcrum plates untill u have the circlip in as they tend to slide around to the back of the axle spade end) do the oppisite and re assemble.
nicko
Anthiron ·
but having said that, what makes u think its the axle, did you inspect the brake drum fully? as if they strip it will send all drive to that wheel and u will have no motion.
DubCrazy ·
the end of the axle came out ...lol kinda gave it away
Anthiron ·
ha ha fair enough
greedy53 ·
cluie bugger
LUFTMEISTER ·
should be a number stamped on the axle. you need to match this number with its replacement. mine had a 12 on it (long axle post '68) mine had the threads stripped.
