74 1303L super
Ashtray jammed shut.
any suggestions / ideas on how to get it opened
greedy53 ·
get at from under the hood i think \
there is not a stray screw in there somewhere seen that before today
frig something must be jammed in there good
theres 2 screws that holds the whole assembly in but if u cant get it to move at all ur not be able to get to them
its only plastic tho if u do break it another one shouldnt be to hard to find
-Joel
[ Edited on 6-9-2007 by DUB74L ]
Do you keep anything in there that could jam it up??
The is a wire spring you can see above that pushes backwards and there is a spring loaded cover that puses upwards on the actual tray.
Can only guess something is jammed
Either thumpit and see if you can dislodge something or you are going to have to drill the front away to get to those screws abd take the whole thing out.
greedy53 ·
don't smoke the car is right think of it as a warning
