Check valves for remote oil coolers
https://forums.aussieveedubbers.com/threads/64903/check-valves-for-remote-oil-coolers
aintgotitmusthaveit ·
When it comes to oil coolers, I am concerned that engine off the cooler is emptying back into the sump and giving a false reading n the dipstick.
When designing hydraulic systems you use check valves to ensure the flow is one way. No automotive types no what the heck I am talking about. So how do you guys avoid it?
Note the oil cooler is mounted at a 45 degree angle with the inlet at the top and the outlet at the bottom thus my fear of draining. (easy to swap I know and that's on for tomorrow!)
Stanley ·
Best you will get is a 1/2 bar check valve. You can modify them by taking out the spring and will work at very low pressure. However check valves are also a good way of making your pump work harder. Pressure drop across an oriface and all that.
dangerous ·
You want one of these:
http://www.speedflow.co.uk/z610.htm
dangerous ·
http://www.speedflow.com.au/catalogue/filtersnvalves/index.html
Made in Australia.
PERFECTO!
THANKS GUYS
barls ·
dangerous wrote:You want one of these:
these guys are good ive got their hoses on my bug as most guys do who running performance equipment. hell he even exports to the states
