typ4 1800 oil
https://forums.aussieveedubbers.com/threads/64976/typ4-1800-oil
flippo1 ·
how much oil does a type-4 1800 hold?
thanks
[ Edited on 12-9-2007 by flippo1 ]
enough to reach the full line on the dip stick:P
flippo1 ·
yeh I know, I think my dipstick is wrong so I wanted to check.
RISKY_VW ·
about 3.5 L
flippo1 ·
thankyou very much risky
flippo1 ·
just fished through some literature, 2.8 litres.
kombikim ·
with VW aircooled engines it is absolutely critical that you check the oil with the car level
as even a slight slope in any direction can drastically alter the apparent oil level with each of my cars I wnet to a flat undercover shopping centre car park filled to exactly full & then went home & checked again where the car is always parked noted what dipstick level is there, & now I happy, got caught out with my first kombi & actually ran out of oil when I thought it was on the low mark
66deluxe ·
Nope its 3.5 litres a type 1 uses 2.5 and a wasser boxer has 5.
modulus ·
Yes, 3.5 litres (with oil filter change). 3 litres (w/o oil filter change) and the distance between the upper and lower marks on the dipstick is 1 litre.
hth
flippo1 ·
cheers guys. My volksie books says 3 quarts which is 2.8-2.9 liters. hrmmm. 3.5 it is then!
