Yes the Intermediate housing is a Gene Berg item
and does not suit 091 gears unless a spacer and different shift rods are used.
It does use a type one nose cone.
I have used solid mountings under the bell housing and intemediate housing.
See some photos here:
http://forums.aussieveedubbers.com/viewtopic.php?tid=58055&page=6
I believe the billet ones I have seen on The Samba are available for 091 gears.
This same basic trans was used for both combinations with just a diff ratio change,
4th gear(late 1600 bus 0.82), and tyre diameters at different stages of performance.
It used aftermarket 1st and 2nd ratios, but stock 1800 bus 3rd and 4th.
It currently has Weddle/Erco gears for Warwick 1/8 mile.
It has a steel billet superdiff, and if you choose to use the factory iron 4 spider diff,
a huge strength increase can be had using a steel hemisphere cover rather than the stock cast one.
Weddle sell these.
RPM at 100km/h is a little difficult without acurate tyre height,
but assuming 635mm(25") 2900 rpm will require an overal ratio of 3.48.
This would suit a 0.76 4th gear and I think Weddle has a .696 or .77 one available.
Without getting to much into the actual ratios you might like to perhaps try stock first to make comparisons,
and depending on actual tyre height...
3.11, 1.86, 1.19, 0.77....?
