Narrowed beam turning circle
https://forums.aussieveedubbers.com/threads/65204/narrowed-beam-turning-circle
Flintstones ·
Hi All
I'm wanting to find from those with narrowed beams what there turning circle is like?
Does one side turn-in better than the other side?
yep, but i haven't had a look to see if its fixable.
Left turns are a bitch.
VWFREAK ·
I'm running a 4 1/2 inch narrowed beam and the turning circle is pretty close to close to 90% of the original depending on how slammed you go.
135's and a little head light clearancing soon help.
Can't beat the look of a narrowed beam
I think I need to see if my steering is central. It doesn't hit anywhere, just runs out of lock.
Flintstones ·
Craig, I agree with the left turns not co-operating
With your tie rods I gather you cut the same amount off each one?
Bone Collector, Did you come across the same problem that Craig and I have experienced?
what did you do with the tie rod lengths, how much did you cut off each one? Did you cut more off the longer one?
what was the fix?
I appreciate your assistance
BOOMERDOG ·
yeah got a narrowed front end on my 54',i use citroen 2cv tyres on the front, 125x15 [firestones] clears the buckets a treat,the way i have welded the sway aways in i have them on full height adjustment ,they only just make the 100mm clearance for nsw regs,but i can wind them to the deck....the narrowed front end does make it a little twitchy but FUN ride...:thumb
[yes all my camber & caster angles/toe -in are correct before anyone asks...]
so all in, the turning circle is alright in my book ..:thumb
[ Edited on 25-9-2007 by BOOMERDOG ]
VWFREAK ·
I just took off 2 inches from each rod and added adjuster nuts to make life a little easier instead of using multi grips for adjustments. Also check your steering box arm is well centered when adjusting everything up. Also possibly check you linkpin shims are correct, as the car may have had a hit in the past, bent arm etc throwing things out of wack.
BOOMERDOG is on the money with the car being a little twitchy. I wouldn't recommend this mod for an inexperienced driver.
[ Edited on 25-9-07 by Bone Collector ]
Flintstones ·
Thanks Guys,
I'm running a BJ beam, which is new so I know it's not bent.
I'll double check on the pitman arm to make sure it's straight and then work my way out to the wheels to ensure I have all the adjustments in check
