FSale: Excellent 76 Beetle Single Sideplate IRS Gearbox **SOLD**
https://forums.aussieveedubbers.com/threads/65336/fsale-excellent-76-beetle-single-sideplate-irs-gearbox-sold
Item for Sale: 76 beetle single sideplate IRS gearbox.
The 76 Irs gearbox is one of the best to use for building a strong box. It has a single side plate case which also has an additional cast rib located on the crown wheel side, the only factory case which has this. The additional external castings make this case a strong basis for a competition gearbox.
I believe it also has stronger gears and steel shift forks etc.........which are added benefits. Fourth gear is also closer to third (So I'm told) Dave???
Price: $390.
Euro_67 ·
longer clutch arm too.
does it have the fine or course gears ??
dangerous ·
Yes stock these had 3.875 diff ratio and 0.931 fine tooth 4th gear.(as opposed to 0.889)
Also the gears are furnace brazed so no need to weld any hubs.
Unless it is from a type 3 it should have the 3.875 diff.
It should have an AT code stamped on the lower rhs of the case.
About their only down side is a soft reverse idler that can lean over and cause popping out.
bump
bump.
strong and cheap !
bump
Klaus ·
its a AT or DC stamping?
I have 3........all with AT
bumpsie
ideal for a splitty IRS conversion!
ghiaguy ·
Does anyone know whether this box will fit into a karmann ghia (if IRS converted)? I assume it would with the usual mods to the top of the forks etc.
ghiaguy wrote:Does anyone know whether this box will fit into a karmann ghia (if IRS converted)? I assume it would with the usual mods to the top of the forks etc.
yes! but you will need to convert to an 'early' style 2-bolt nose cone/selector rod housing to fit the chassis mount. 2 min job!
bumpsie
still have it for sale 🙂
waltermitty ·
Craig why is it the perfect box for a IRs splitty conversion are the ratios better suited? I am collecting parts ATM so I am intereted.
Is the box tested? are syncros etc, good or what?
regards Mitrchell
well if you are going to use a beetle box this one is the best.....................read above.
Brad ·
Craig Torrens wrote:I have 3........all with AT
So is that $390 for 3 ?
Yeah - why not! 🤪
waltermitty ·
Craig i read above still would like to know
Is the box tested? are syncros etc, good or what?""
regards Mitrchell
yep.........just add $1100 for delivery. 😂
waltermitty wrote:Craig i read above still would like to know
regards Mitrchell
So what do you want to know ?
#1 It has the strongest factory case
#2 It's a single side plate box
#3 The sideplate that it has is the strongest factory plate (additional cast rib)
#4 Strongest factory diff (3.875)
#5 Lower 4th gear ratio (closer to third)
#6 Steel shift forks
#7 Gears are furnace brazed so no need to weld any hubs.
Gearbox has good syncos etc..............was briefly tested before the car wrecked.
waltermitty ·
WOW !
Craig if you would read my post i guess i want to know what condition its in, as per "are syncros etc good or what?".
I can see now you tested before removal but what were the results??? DID IT SHIFT AND WORK WELL?? or was it fu*ed?
I am not tyre kicking and am not trying to be difficult but i just believe in" CAVEAT EMPTOR"
Love Mitty
Morts ·
Craig, will you please contact me on 0411 205 590 re gearbox - thanks.
Michael.
waltermitty wrote:WOW !
Love Mitty
The use of the word "excellent" in the title may give you a hint to the condition..................Shifts well, no noises, syncro's great even with high speed down shifts from 3rd back to second and then back to first..............................Sale now pending.
waltermitty ·
"Excellent" hope the sale goes well , then sometimes even some "excellent " sales dont work as they should, good luck,
too hard for me
merry xmas mitty
Brad ·
Cool, done deal .. oh I will pickup so that would make it $390 for 3 x Single side plate gearbox's in good nick with AT numbers .. yeah ?
Morts ·
Hi Craig - I will not be needing the gearbox now.
All the best, Michael
No worries Michael.👍
Glad you found one closer to home.
SOLD
