The front and rear clips have been cut off at one stage to make a baja. The rear clip has been replaced (only pop riveted back on) and the front clip in missing.
The guard and bonnet are fiberglass.
No motor and the gearbox is a tunnel case not a split one.
It has 1954 stamped on the id plate does this make it a '54 or a '55 ?
h ·
hmmm..
from ya pics it should have a batwing if 54, but it has a 56-57 steerwheel and da 'made in' badge should have West Germany on it from memory yeah..
what is the date stamped on the back of the speedo, usaully a clear sign of build date..
good luck..
mackaymanx ·
Well the plate says "made in germany", the id plate says "Baujahr 1954". The doors are the early style with the 2 locating lugs.
"MKA2232"
The photo of the chassis number isn't clear enough to make out and what I can make out dosen't make sense.
captainvw ·
Yep thats a 54
vwtyp2 ·
I hope it's cheap.
MickH ·
It's very cheap.....:o
mackaymanx ·
He's looking for $1200 for it.
kevercop ·
Nice car mackaymanx!
Ar you the owner now ? 😉
Turbo54 ·
there was one like this on ebay from adelaide... is it that one?
T54
mackaymanx ·
No, it's local to where I am. Will be having a closer look in the next few days, I want to pull it outside and empty the junk out to get a better gauge on it's condition
bushed ·
can i have 2 nd dibs on it pleese
maybe cheap but a fair bit missing
I have
box and bonnet and gear for you if you take it.
Turbo54 ·
Mackaymanx, make sure all the door mechanicals and the window winders etc work as they dont swap over with anything later and are hard to find!
bushed, I am interested in the bonnet if you want to sell it if it is straight and has the 5 mounting bolt holes and the triangle plate under the badge.
T54
kroozzn63 ·
so what happened?
h ·
yeah did ya get it?
mackaymanx ·
I passed on it. too much missing, too much money and no space to store it at present.
